Modeling Loads in STAAD.Pro
Learn how to model loads in the STAAD.Pro Analytical Modeler or the STAAD.Pro Physical Modeler.
   Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Generating Wind Loads in STAAD.Pro
Learn how to generate wind loads in STAAD.Pro according to the ASCE Main Wind Force Resisting System.
Generating Static Seismic Loads in STAAD.Pro
Learn how to generate static seismic loads in STAAD.Pro according to the IBC Equivalent Lateral Force Procedure.
Generating Dynamic Seismic Loads in STAAD.Pro
Learn how to generate dynamic seismic loads in STAAD.Pro according to the IBC Modal Response Spectrum Procedure or the Seismic Response History Procedure.
Additional Resources
Want to learn more? See the additional resources for modeling topics in STAAD.Pro.
 Knowledge Base ArticlesRAM|STAAD ForumSTAAD Ideas PortalSTAAD Product Information
 STAAD Analytical Modeler TrainingSTAAD Physical Modeler TrainingSTAAD Technical DiscussionsSTAAD Tips and Tricks
 STAAD Coffee Corners (NAOU)STAAD/RAM Coffee Corners (EMEA)STAAD Coffee Corners (SEAPAC)RAM Coffee Corners (NAOU)
Need help? Connect with us using the Bentley Support Portal.
