RM Bridge Training Examples is where the self-paced training examples can be accessed for user technical reference by choosing from the list as shown in the screenshot below. Check each article for more technical details about the respective examples' content.
Simple and complex beam and bridge models and issues are addressed. Structural engineering technical know-how is expected from the users. Eurocode, DIN, and AASHTO codes are generally used.
Each option contains a list of examples that can be used for learning purposes. Titles and descriptions indicate the subject to make the selection easier. The datasets can be loaded/imported, and the examples' calculations run. A subdirectory of the current project directory is normally created for performing the analysis of the demo example; however, the user may select any other directory. All listed examples have a description document, including theoretical background, in the .pdf format.
They are part of the product installation and can be found in the menu at File\Examples\Training examples.
