Document Information
Document Type: FAQ
Product(s): OPEN BRIDGE MODELER
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: How to generate the Deck Elevation Report?
ANSWER:
To get the deck elevation report at the Edge of the deck then you have to select
Report Type – Station/Offset/Elevation
Transverse Lines – Normal to Alignment.
Points Per Span – 10 -20 as per your project requirement.
- Under common References select “ Left/Right Deck Edge”.
- To get the Elevation at Along the Beam Path then Select the “Beam Path” Option.
- Then click on Generate to create report
- Then the program will Draw Perpendicular lines at every 10th point the program will create Intersection Points.
- Then the elevations are shown at those points.
- If the Bridge is Skew then the user can generate the elevation report “Parallel to Start Support” or “Normal to alignment” as per the project requirement.
- You can also toggle on Individual Paths to generate elevation reports along each beam paths.
