Release Date: 25th July 2023
Version: ISM Revit Plugin v12.02.00.07
Restore support for 2022
Previously, some installations of REVIT 2022 reported an error when instantiating. This is now resolved.
Download Instructions
- The recommended approach is to download and install iTwin Analytical Synchronizer.
- Alternatively, and for existing ISM Revit plugin users, ISM Revit plugin can be downloaded and installed via CONNECTION Client.
Special Notices
The installation of ISM Revit Plugin will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2022, Revit 2023 and Revit 2024. iTwin Analytical Synchronizer automatically packages ISM Revit Plugin.
