| | Product: | MicroStation | |
| | Version: | V8, XM, V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Annotations | |
| | Subarea: | N/A | |
How to place a dimension between two parallel curves (so it appears as image 1 below)
Option 1
- Use Dimension Arc Distance tool
- To use, go to the menu Tools > Dimensions > Radial Dimensions > Dimension Arc Distance
- Click on first curve, then second curve and place dimension
Option 2
- Start the Dimension Linear tool with Alignment set to True
- Using Snap Nearest, snap the start of dimension to one of the curves
- Select Snap Perpendicular and snap to the second curve
- Place the dimension
- See this link for a demonstration video:
Image 1
See also
Other language sources
| | Original Author: | Conor King | |
