| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | General | ||
| Original Author: | Ranjana, Bentley Technical Support Group | ||
Question:
I have a problem and it is that when I start the RCDC it shows me everything in English system units and it does not allow me to change it to the metric system. I appreciate if you can help me with this.
Answer:
I believe you are using the ACI code here. For ACI code we have 2 unit versions for each code. You will notice a suffix M which indicates metric unit system.
So, if you select any code with ACI318M, by default Metric unit will be activated.
