| Version(s): | All | ||
| Area: | STAAD.Pro Analysis Solutions | ||
| Subarea: | Seismic Analysis | ||
| Original Author: | Abhisek Mandal, Bentley technical Support Group | ||
I am trying to analyze a structure which consists of a large dia pipe supported at discrete points. I am unable to get STAAD to analyze this for UBC loads.?
When the UBC committee came up with the recommendations for analysing structures subjected to earthquakes, the type of structures they had in mind were conventional style buildings where the base of the model, namely, the points where the supports are located is at the lowest elevation with respect to the rest of the model.
If you look at the UBC procedure, it involves computation of the base shear, which then has to be distributed over the height of the building, so that one can then calculate the inter-story shears. A certain amount of the weight gets lumped at the highest point of the building, and the rest gets distributed along the height. In other words, the principle is that a mass at any height of the building is subjected to an acceleration and the force caused by the acceleration is represented by a concentrated force where the mass is located. The summation of all such forces at a given floor cause the columns beneath that floor to be subjected to a shear force.
When you talk of a model like a pipe which is defined as line members attached to several collinear nodes, all of which are at the same elevation, the UBC rules become impossible to apply. The fact is, to analyse your structure for seismic effects, you do not even need the elaborate procedure of the UBC code. You can take the selfweight, and any imposed loads on the pipe, and apply them along a horizontal direction like X or Z with a factor, and you will get what is normally expected in a seismic analysis.
So, you just have to have
LOAD 2
SELF X n
where n is a number like 1.5, which represents that there is a net force of 1.5 times the weight of the structure acting along the X direction due to an earthquake. For better handling of the distributed loads, you might want to consider defining several nodes along the length of the pipe, between supports.
