| Version(s): | All | ||
| Area: | OpenSTAAD | ||
| Subarea: | Property | ||
| Original Author: | Bentley Technical Support Group, Shreyanka Bhattacharjee | ||
Problem Description:
How to remove property from members using OpenSTAAD function
Function RemovePropertyfrombeam needs to be used for this task
Parameter:
[Input] beamNo: The beam number ID
Sample VBA Syntax(The macro will remove property from member 1,2,3):
Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
Dim beamNo(2) As Long
beamNo(0) = 1
beamNo(1) = 2
beamNo(2) = 3
For i = 0 To 2
objOpenSTAAD.Property.RemovePropertyfrombeam beamNo(i)
Next i
