| Product(s): | MicroStation, PowerDraft | ||
| Version(s): | 08.11.09.459 | ||
| Area: | Configuration | ||
| Subarea: | General | ||
| Original Author: | Conor King, Bentley Technical Support Group | ||
"MicroStation (version given) has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
MicroStation crashes when opening any file and a Windows error message appears. There are no MicroStation Exception Logs or MiniDump files created. There are a number of reasons why this error might be generated but one such case is related to a file usually stored in the dwgdata folder.
Check the location path of the folder dwgdata, which is pointed to by the variable MS_DWGDATA. If this folder is on a network share, it may be causing the issue. There is a file in this folder called MstnShxFileList.csv, which, if it becomes corrupt while on a Network Share can cause MicroStation to crash just after start up. The purpose of the file is to locally cache metadata about SHX files, so that if there are libraries of these on a network share, it can improve the startup performance of MicroStation. The file can become corrupt by many MicroStations accessing this file simultaneously. By default, this file is stored locally.
Search for the file MstnShxFileList.csv
This should be located in the folder pointed to by MS_DWGDATA
An msdebug can be used to find the path to MS_DWGDATA if needed
Once found, either remove this file from the folder, or, rename the file (e.g. MstnShxFileList.bak)
Start MicroStation once more to see if issue is resolved
Note: If the file must be kept on a network share, the file should be write protected.
