Product(s): | MicroStation | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | Text | ||
Subarea: | Text Styles |
Underline is too close to the text. How can the distance between text and underline be adjusted?
Select the desired text style)
Under/Overline > select “Underline”
Enter the offset
XXXXXXX(Add links as needed for other relevant Be Communities content.)XXXXXXX
