| Product(s): | Microstran | ||
| Version(s): | V8i | ||
| Area: | User Interface, Microstran | ||
| Original Author: | Ranjana Shinde | ||
Question:
The file/view/design etc. menu along the top is gone.. All my toolboxes are out of Wack and not in their usual position anymore:
Open Microstran and Press Alt V and T simultaneously. You will see the options as shown in the image below, then customize these and click on reset .
OR
Uninstall Microstran and delete the same through Registry Editor located at
Computer-->Hkey Current User--> Software-->Bentley-->Microstran-->Microstran Connect edition
