Product(s): | MicroStation | ||
Version(s): | 10.06.00.38 | ||
Environment: | N/A | ||
Area: | Configuration | ||
Subarea: | Workspaces |
The following blogs posts describe the creation of a Custom Configuration for MicroStation:
CONNECT Edition - Custom Configuration - Part 1 : Initial Creation Steps
CONNECT Edition - Custom Configuration - Part 2 : Standards Folders
CONNECT Edition - Custom Configuration - Part 3 : Standards CFG Files
CONNECT Edition - Custom Configuration - Part 4 : Standards CFG File Contents
CONNECT Edition - Custom Configuration - Part 5 : Separating Project Data from Standards
CONNECT Edition - Custom Configuration Guides
"Looking Under the Bonnet..." CONNECT Edition Configuration articles
