RM Bridge as a component of OpenBridge Designer is part of the product consolidation strategy where all bridge solutions are steadily united to become one. The analytical model, a mathematical simplified model, used only for the calculations can be directly created based at the physical model created, i.e., all the geometrical model from OpenBridge Modeler will be reutilized in a BIM Workflow. A Standalone workflow, where everything is defined in RM Bridge Enterprise is still available. Watch this video and learn more at the link from our Bentley OpenBridge YouTube channel: https://youtu.be/CxYgyb-yRL8
Current users: please note that all Enhancements will become available only in the new versions included in OBD!
More general information about OpenBridge Designer can be found at the wiki link below:
communities.bentley.com/.../standalone-workflow-for-analysis-and-design
