| Version: | V8i, CONNECT | ||
| Area: | Interchange | ||
| Subarea: | JT |
Export a file to JT format including text and dimensions
When exporting a file to JT format by default only the drawing entities will be included in the export process and text and dimensions will be filtered out.
1. Select the parts of the dgn model that need to be exported in JT format
2. Select "File->Export->JT"
3. Scroll the horizontal bar of the "JT Output" dialog until "Dimensions" and "Text" are displayed and tick them as required for each individual file displayed in the dialog. There should be only one file displayed if there are no references attached and selected for the conversion.
4. Click on "Ok" to complete the file conversion
More details about JT conversion options and workflow are explained in the "Menu->JT Exporter Dialog" section of MicroStation's help
| Original Author: | Marco Salino |
