Project file set up to show files in MicroStation Manager
 Product:MicroStation
 Version:V8, XM, V8i
 Environment:N\A
 Area:Configuration
 Subarea:Workspaces
How can a Project Configuration File (PCF) be set up so that the directory for design files will show up in the Microstation Manager?
In the PCF file the variable MS_DEF will need to be defined to point to the location of where the design files are stored. When the project is then chosen the Microstation Manager will reflect the location of the DGN file.
Other language sources
