RM Bridge can consider Variable Loads in many different ways, in time and space. For the loads to be variable either one of the options below should be selected:
Note: Only the Load Set in the bottom list that has this same option selected is going to be considered as variables.
The variables can be defined by expressions or tables as explained in the link below:
communities.bentley.com/.../variable-loads-by-factors-variables-expressions-or-tables
