| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | Column & Shear Wall | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How to control the link spacing in columns?
You can go to settings and reinforcement settings option and set maximum limit as 200mm for link spacing. Now program will calculate the actual spacing and if that is greater than 200mm, it will set that as 200mm. But in case of less than 200mm, it will print the actual value. You may also use spacing round off factor additionally if required for other cases.
