Clip Volume Toggles are missing!
Product(s):MicroStation
Version(s):V8i and CONNECT Edition
Environment:N/A
Area:View
Subarea:Clip Volumes
Problem Description
The Clip Volume Toggles are missing when I select a Section/Plan/Elevation cut to modify.
The reason is that Select Handles has been Disabled in the Select Tool dialog.
Steps to Resolve
Enable Select Handles in the Selection Tool dialog.
 Original Author:Anders OMahony
