| Version: | CONNECT | ||
| Area: | Parametrics | ||
| Subarea: | General |
Having created a Parametric Solid by Extruding a Profile, I want to edit the Parametric Solid by replacing the Profile with another.
To replace the profile
5. Select the newly drawn required profile and except with a Data point in the View
| Original Author: | Carl Myhill |
