6. Release Note
STAAD Advanced Concrete Design 2023 Minor 6 (23.00.06.07)
We are pleased to announce the release of STAAD Advanced Concrete Design (RCDC) V2023 Minor 6 (23.00.06.07). This is a Minor release and consist of software security updates.
STAAD Advanced Concrete Design 2023 Minor 5 (23.00.05.04)
We are pleased to announce the release of STAAD Advanced Concrete Design (RCDC) V2023 Minor 5 (23.00.05.04). This is a Minor release and consist of software security updates.
RCDC (SACD) V2023 (23.00.04.12)
This release mainly consists of resolution of priority bugs. The following are defects resolved in RCDC V23.00.04,
1. Pedestal design – Issue in generating drawings and Design calculation report with ductile design settings selected for American and Indian design codes
2. Pedestal design – forces at bottom of pedestal were not updated if user changes the Pedestal height
3. Column design with Axial tension – Incorrect design moment considered for design
4. Column design – Stability index value not updated after merging the levels
5. Beam design – Grouped beams do not show critical combination in the design calculation report
6. Beam Design– Repeat load cases were ignored for crack-width check for the beam design
7. Beam Ductile design –Software goes into non-responding mode
8. Combined wall –Error generating design calculation report for ACI and Euro design codes
Release Notes: link
RCDC (SACD) V2023 (23.00.03.63)
This release mainly consists of implementation of minor enhancement and priority bugs. The following are some of the minor enhancements added to RCDC V23.00.03,
1. Calculation of Curvature ductility factor used for the Ductile Columns of Euro codes.
RCDC is now providing following two options to consider the curvature ductility factor.
• Compute curvature ductility factor based on the various inputs available in the program.
• User defined curvature ductility factor.
2. Projection (offset) of pile-cap from edge of pile - The maximum permissible offset value has been now increased so that user can provide the higher values.
3. Pile capacity values (compression, Tension and shear) are allowed to provide up to two decimals in RCDC so that user can provide more accurate pile capacities for the pile cap design.
To find out more about these features and other enhancements, please refer to the attached release notes.
SACD(RCDC)_Release Note - 2023.00.03_R0
RCDC (SACD) V2023 (23.00.02.43)
We are pleased to announce the release of RCDC (STAAD Advanced Concrete Design / SACD) version 2023 (23.00.02.43). This is a minor release that consists of the following features,
SACD(RCDC)_Release Note - 2023.00.02_R0
RCDC (SACD) V2023 (23.00.01.24)
We are pleased to announce the release of RCDC V23 (23.00.01.24). This is a Patch Release to RCDC V23 (23.00.00.98) release. This release includes defect corrections in the Beam design module.
Resolved Issues:
Beam Auto Design - Error in the performing beam auto design operation in certain scenarios.
RCDC is unable to perform the auto design operation of beam design due to an error in reading supports of the beam. This is not common but is found in the following cases.
  1. Beam entirely overlapped on the column/wall. The member starts node and end node are found within the extent of the length of the column/wall.
  2. Circular curved beams are present in a structure. The curved beam is modeled by creating multiple small straight segments with some angle in plan between the support to get the behavior of a curved beam.
The issue was found in the reading of the geometry of the beam. The beam end supports are not identified properly in the above-mentioned cases, due to this the exception error occurred in the auto-design operation of the beam. The user is unable to design beams in RCDC.
This issue has been resolved in RCDC V23.00.01.24. The correct column/wall supports are now identified for beams and auto-design operation can be performed without any error.
RCDC (SACD) V2023 (23.00.00.98)
We are pleased to announce the release of RCDC (STAAD Advanced Concrete Design / SACD) version 2023 (23.00.00.98). This is a minor release that consists of the following features,
1. Beam Crack-width check for corner Rebar - at the corner and side face of the beam – Indian code
2. Beam flexural calculation enhancement – ACI and NSCP codes
3. AS 3600:2018 – New check added for Minimum percentage reinforcement for the column based on axial load
4. Addition of 6 & 9 mm rebars for Column and Beam design in ACI (metric) and NSCP codes
5. Load Type reading for load cases from STAAD
SACD(RCDC)_Release Note - 23.00.00
RCDC (SACD) Connect Edition V11 Update6 (11.06.00.56)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.06.00.56 version. This is a Minor release which consist of following features,
1. Ductile column & Beam Joint check – Beams with end release have been Ignored – All codes
2. Column PM Interaction curve Presentation – 2D PM curve added– All codes
3. Column and Wall – Option to set maximum diameter for shear links – All codes
4. The beam is identified as non-Ductile if the beam is released at any one of the ends – All codes
5. Beam separate input for the side clear cover – All codes
6. Cantilever beam bottom reinforcement detailing without maximum spacing check if the bending moment is zero.
7. Update the design if the Footing Design file is created through the pedestal design
8. Optimizing the shear reinforcement provided in the beam if ductile, torsion and other spacing criteria are governing
To find out more about the features added in this release, refer the attached release note.
SACD(RCDC)_Release Note - 11.06.00
RCDC (SACD) Connect Edition V11 Update5 (11.05.00.155)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.05.00.155 version. This is a Minor release which consist of following features,
  1. ‘Update Pile-cap Design’ functionality in the Pile-cap module with a new analysis file- All Design codes
  2. The current footing design logic improved to accommodate axial force from columns that are tensile and when stability checks are performed
  3. General improvements in various modules of the ACI 318-2011 code
  4. 13mm rebar diameter added for the Euro code
  5. Cantilever beam to be ignored in the joint check of ductile column design
  6. Logic improvement in the shear design of the tank slab to satisfy the check
SACD(RCDC)_Release Note - 11.05.00
RCDC (SACD) Connect Edition V11 Update4 (11.04.00.151)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.04.00.151 version. This is a Minor release which consist of following features,
  1. ‘Update Beam Design’ functionality in the beam module with a new analysis file- All Design codes
  2. Reading and ‘Design of Beams at Foundation Level’ without column modeled
  3. Different Reinforcement Grades for Main and Secondary reinforcement for Column module- All Design codes
  4. An additional option to calculate the Moment Capacity Reduction Factor (φ) for column design as per AS 3600:2018
  5. ‘Design Change’ report for the ‘Update Design’ functionality in the column module
  6. An option to select the Strength Reduction Factor (φ) for shear design of special frames for ACI & NSCP code
  7. Pile-cap design for Columns with ‘Tensile Axial’ force- All Design codes
  8. Reading Tapered tank wall from STAAD physical modeler
SACD(RCDC)_Release Note - 11.04.00
RCDC (SACD) Connect Edition V11 Update3.1 (11.03.01.10)
This is a Hot fix to RCDC V11 Update 3 release. This release includes defect corrections in the ductile column design module.
Resolved Issues:
  1. Ductile Column design – Error in the calculation of Issue in the final design of main reinforcement while performing various redesign operations.
For columns that are designed using the Auto Design facility, RCDC allows some further redesign operations to be performed on those columns. Examples of these redesign operations are:
a) Level Grouping - which allows all the columns at a given level to have the same reinforcement
b) Level Ungrouping - which is the opposite of what is described in (a) above
c) Grouping of any two or more columns specifically chosen for this task
d) Un-grouping of any two or more previously grouped columns specifically chosen for this task
e) Grouping/un-grouping using the Snapshots facility available in the Reports menu of RCDC
f) An ignore/include operation is performed for some columns
An error is present in the reinforcement that is calculated for ductile columns that are subjected to the afore-mentioned redesign operations if the user performs the following steps in the sequence described
i) Performs Auto-design
ii) Closes the file
iii) Re-opens the file
iv) Performs one or more of the redesign operations described in (a) through (f) above
The error is in the calculation of the main reinforcement of the column. There are chances that the final reinforcement calculated would be lesser than the required reinforcement.
This issue has been resolved in RCDC V11 Update 3.1. The correct design is now performed for the various redesign operations. The provided value of the reinforcement calculated for the above various redesign operations now satisfies the steel area required to resist the loads.
  1. Column design – ACI 318 (FPS unit codes) – Issue in length parameters on redesign Screen for grouped columns/walls.
After the Auto design is performed for the column/wall, RCDC allows providing various parameters on the redesign screen. It also allows modifying the length parameters on the redesign screen. Length parameters include the unsupported length and effective length factor for the selected column/walls. If the column/walls are grouped, RCDC allows providing separate unsupported length and effective length factors for each column/wall.
For the ACI 318-2011, ACI 318-2014, and ACI 318-2019 (FPS unit codes) there was an error in displaying the length parameters on the redesign screen for the grouped column/walls.  The values of the unsupported length and effective length factor shown on the redesign screen for grouped columns/walls were not consistent with the values calculated during auto design or values provided by the user.
This error too has been resolved in the RCDC V11 Update 3.1 release. The correct unsupported length and effective length factor values are now shown on the redesign screen which should enable the user to perform the redesign operations.
RCDC (SACD) Connect Edition V11 Update3 (11.03.00.141)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.03.00.141 version. This is a Minor release which consist of following features,
1. Addition of American code ACI 318-19 (English Unit)
2. Update design functionality in footing module with new analysis file- All Design codes
3. Use of different Steel grades for Main and Shear reinforcement (Beams) – All Design Codes
SACD(RCDC)_Release Note - 11.03.00
RCDC (SACD) Connect Edition V11 Update2 (11.02.00.200)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.02.00.200 version. This is a Minor release which consist of following features,
1. Addition of German Annex to Euro code – DIN EN 1992-1-1/NA :2013-04
2. Addition of American code ACI 318M-19
3. RCDC compatible with Windows 11
SACD(RCDC)_Release Note - 11.02.00
RCDC (SACD) Connect Edition V11 Update1 (11.01.00.180)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.01.00.180 version. This is a Minor release which consist of following features,
1. Addition of Soil and Fluid load in the load case list
2. Addition of load type for Earthquake and Wind loads in Euro code
3. Addition of Tapered and Stepped type wall in the Tank structure module
4. Exporting Tank geometry and reinforcement data to i-twin model through ISM
5. Addition of Pile-cap deign in Australian code – AS 3600:2018
SACD(RCDC)_Release Note - 11.01.00
RCDC (SACD) Connect Edition V11 (11.00.00.143)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 11.00.00.143 version. This is a major release which consist of addition of Australian code and Belgium Annex for BS EN Code.
SACD(RCDC)_Release Note - 11.00.00
RCDC (SACD) Connect Edition V10 (10.00.00.278)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 10.00.00.278 version. This is a major release which consist of addition of new code and all new tank structures design module.
NSCP – 2015 – (National Structural Code of the Philippines) is added in RCDC. With the addition of this code, all the structural elements can now be designed for NSCP – 2015
New module is added in RCDC for design of tank structures (liquid retaining structures). This is now available as General release. The design would be based on EN 02 -1-1- 2004 + EN 02 -3 – 2006 UK code
Calculation and design for sway shear at supports in ductile beam as per from EN 08 – 1 -2004 has been implemented for medium and high-class ductility frames.
SACD(RCDC)_Release Note - 10.00.00
RCDC (SACD) Connect Edition V9 Update-4 (09.04.00.128)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 09.04.00.128 version
RCDC will read the SRSS and ABS type load combinations available in STAAD. Load combination form would be like repeat load cases for SRSS & ABS load combinations
Reinforcement detailing of Ductile Beam (clause 7.1.1 of IS 13920-2016 and 21.2.7.3 of ACI 318M-2011 ) as per column size for IS and ACI code is available.
New module is added to RCDC for design of structures with tanks (liquid retaining structures). This is added as ‘Tech Preview’ feature. The design would be based on EN 02 - 2004 + EN 03 – 2006 UK code
SACD(RCDC)_Release Note - 09.04.00
RCDC (SACD) Connect Edition V9 Update-3 (09.03.00.25)
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 09.03.00.25 version.
RCDC will now read the member forces from STAAD file for Repeat Load Cases with much easier process.Two Methods are available for Column capacity calculation for Joint check as per IS 13920-2016.  Euro Code enhancement related to Shear reinforcement calculation for all modules available in RCDC.
SACD(RCDC)_Release Note - 09.03.00
RCDC (SACD) 09.02.00.32
RCDC 09.02.00.32 is now available with some exiting features and some important enhancements.
Design of Gravity column is included in RCDC for Indian an American concrete design codes.
SACD(RCDC)_Release Note - 09.02.00
RCDC (SACD) 09.01.00
We are pleased to announce a release of RCDC (STAAD Advanced Concrete Design / SACD) 09.01.00 version.
User can now design shear walls if it is modelled as a parametric surface in STAAD.
SACD(RCDC)_Release Note - 09.01.00
RCDC (SACD) 9.0.0
RCDC (SACD) is coming with Major release which consist of ACI 318-2011 and ACI 318-2014 with English Unit and rebar reference numbering as per US standard. These codes will be available for all design module like Column, Beam, Footing, Pile-cap and slab.
To find out more about the features in this release, refer attached release note.
SACD(RCDC)_Release Note - 9.0.0_R0
RCDC (SACD) 8.0.1
RCDC (SACD) is coming with a minor release which consist of ACI 318-2011 and ACI 318-2014 with FPS unit and rebar reference numbering as per the US standard. Currently these codes are available for Beam design Module
It also includes the Update design feature for column. The advantage of the ‘Update Design’ option is that user can check the existing design (based on earlier analysis file) with the revised analysis file.
SACD(RCDC)_Release Note - 8.0.1
