| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | General Steel Design Solutions | ||
How do I include detailed steel design results in a report?
You can include the "Steel design Detail" item in a report to ensure it includes the full set of steel design information. To do this, run the analysis for your model and then click on "Reports" as shown below:
The report setup tool will appear to the right where you can pick and choose the items you wish to include. Go to Post Processing -> Steel Design Results as shown in the screenshot below and there you will find the "Steel Design Detail" item:
Click the green plus sign next to "Steel Design Detail" to add it to the report:
