| Product: | MicroStation | |
| Version: | V8, 2004, XM, V8i, CONNECT | |
| Environment: | N\A | |
| Area: | Graphics Display | |
| Subarea: | General | |
How to apply Transparency to a filled shape or element
Option 1
- Select the Shape or Element in the view by clicking on it once
- From the Active Attributes Tools at the top, click on the Element Transparency as shown in image 2
- Select a Transparency value, the higher the value, the more transparent the element becomes
- Once a value is selected, the element should appear transparent, see image 4
- If it does not, see Transparency not displayed
Option 2
- Right click on the Element and select Properties from the pop-up menu (Element Information in older versions), see image 3
- The Element Information dialog appears, from the General section click in the Transparency field and choose a value
Image 1 - Filled Shape
Image 2 - Active Attributes - Element Transparency
Image 3 - Right click for Element Information
Image 4 - Transparent Shape
See also
Other language sources
| Original Author: | Conor King | |
