FAQ: How to create an Abutment without the back wall?
Answer: In OBM, for an Abutment, in the Substructure Template, at the Cap, the user has to set both back wall main parameters to zero, as shown below.
Back Wall:
Other details, like Check Walls and Piles can still be added, resulting in the elements as shown in the image below.
