Place Strip bearing on a crowned cap for RC Slab bridge.
When you have a crowned deck with a crowned cap for the RC Slab model, one cannot have the bearing flat bearing follow the crowned cap.  One can use the Variable constraints for the deck and vary the thickness of the deck at desired location.  Here is an example:
