(1) Move to go Beam Layout definition.
(2) Select the check box for Advanced Bearing Definition.
(3) Enter the desired numbers of bearing into the input of the Number Required.
(3) Specify the spacing and also the offsets.
(4) Select the Save button.
(5) Place the bearing, and then OpenBridge Modeler will place the bearings that are based on the above inputs.
