Document Information
Document Type: FAQ
Product(s): OPEN BRIDGE MODELER
Version(s): All
Original Author: Bentley Technical Support Group -VM
ANSWER:
In Place Diaphragm window the Bottom Vertical and Top Vertical offset definitions are mentioned below.
Start Beam & End Beam Offset:
Top vertical -- Top Offset above the beam which will be in Positive sign.
Bottom Vertical --Bottom Offset which is below the beam and sign will be negative.
