| Version(s): | All | ||
| Area: | OpenSTAAD | ||
| Subarea: | Support | ||
| Original Author: | Bentley Technical Support Group, Shreyanka Bhattacharjee | ||
Problem Description:
How to remove support specification from specified node(s) using OpenSTAAD functions
Function AssignSupportToNode can be used for this task
Parameter for AssignSupportToNode:
node: The node number ID(s)
varnSupportNo: Support Reference number ID
Sample VBA Syntax:
Dim node() As Long
Dim nodecount As Long
Dim varnSupportNo As Long
nodecount = 1
ReDim node(nodecount)
node(0) = 52
node(1) = 65
varnSupportNo = 1 'No Support
For I = 0 To nodecount
objOpenSTAAD.Support.AssignSupportToNode node(I), varnSupportNo
Next I
