Product(s): | MicroStation | ||
Version(s): | 08.11.09.908 | ||
Environment: | N/A | ||
Area: | Other | ||
Subarea: | N/A |
User gets Dot Net Framework error when opening MicroStation V8i
Following is the information from the Dot Net error, "Details" section.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Bentley.MicroStation.Exceptions.CommandTableException: Keyin "CONNECTAdvisor CONTEXTUAL START" not mapped to method in AddIn CONNECTAdvisor.CONNECTAdvisorMain
at Bentley.Internal.MicroStation.CommandTables.RegisterCommandNumbers(KeyinTree tree, AddIn app)
at Bentley.Internal.MicroStation.CommandTables.LoadKeyinTables(String xmlFileName, AddIn app)
at Bentley.MicroStation.AddIn.Initialize(IntPtr mdlDescriptor, String appXmlFileFqn)
at Bentley.MicroStation.AddIn..ctor(IntPtr mdlDescriptor)
at CONNECTAdvisor.CONNECTAdvisorMain..ctor(IntPtr mdlDescIn)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle._InvokeConstructor(Object[] args, SignatureStruct& signature, IntPtr declaringType)
at System.RuntimeMethodHandle.InvokeConstructor(Object[] args, SignatureStruct signature, RuntimeTypeHandle declaringType)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Bentley.MicroStation.AddIn.Load(String[] commandTail, IntPtr mdlDesc)
Try the following steps to solve the issue. If a given step is not working, go to the next one:
V8i - ZIP the following files (backup) and delete it from the locations.
C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\GUI\CONNECTAdvisor.dgnlib
C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\appl\CONNECTAdvisor.cfg
