Now Available, the first Commercial Release of OpenBridge Modeler CONNECT Edition. v10.03.00.03.
Bridge Modeling on the MicroStation CONNECT platform and OpenRoads with OpenBridge Modeler CONNECT Edition, OBM CE.
Key Features:
3D parametric bridge modeling focusing on:
Segmental bridges (span-by-span and balanced cantilever)
Box girder bridges
Slab bridges
Prestressed concrete girder bridges
Steel girder bridges
Extensive substructure modeling
Piers (multi-column, pile bents, wall piers, & custom piers)
Abutments (stem wall and pile cap)
Bearings and bearing seats
Reference or import of civil data, from legacy Civil products or OpenRoads Designer
Horizontal alignment, vertical profile, terrain
From GEOPAK, InRoads, MXRoad native files
Civil consensus model
Analytical connection
Geometry reports
Input echo
Deck elevations
Bearing seat elevations
Estimated quantities and cost reports
Generate i-models with engineering attributes
Download the installer from Fullfilment Center ( Software Downloads).
