Product(s): | MicroStation | ||
Version(s): | 10.10.00.23 | ||
Environment: | N\A | ||
Area: | Printing | ||
Subarea: | Print Def/CAD |
The printer HP Design Jet 1050C is not working with MicroStation CONNECT Edition.
"False parameter" error is shown in the message center.
The affected printer is a very old model (available drivers are from 2004). MicroStation CONNECT Edition is a 64 bit application and there are no 64 bit drivers for this plotter.
As a workaround, print to PDF and then from PDF to the physcial plotter.
Original Author: | Grzegorz Cwiek |
