| Version: | XM, V8i, CONNECT | ||
| Area: | Base Geometry | ||
| Subarea: | N\A |
Where are the Points Tools located?
In MicroStation V8i:
Points Tools are located under Tasks > Drawing > Linear tools:
In MicroStation CONNECT Edition:
Points Tools are located under Drawing workflow > Home tab > Placement tools:
Or Task lists > Linear > Points
Bentley Communities - Modeling and Visualization
