Connector
| Design Code | Column Section | Beam Section | Joint/Connection Options |
- AISC: Single Plate (SP)
- AS: Web Side Plate (WSP)
- BS: Fin Plate (FinP)
- CSA: Single Plate (SP)
- EN: Fin Plate (FinP)
- GB: Single Plate (SP)
- IS: Web Side Plate (WSP)
- NZS: Web Side Plate (WSP)
- I-Shaped
- Rectangular
- Circular
- Beam Skew Angle: Max 60º
- Beam Slope Angle: Max 45º
- Plate Type: Standard or Extended
- AISC: End Plate (EP)
- AS: Flexible End Plate (FEP)
- BS: Flexible End Plate (FEP)
- CSA: End Plate (EP)
- EN: End Plate (EP)
- IS: End Plate (EP)
- NZS: Flexible End Plate (FEP)
- Connection Type: Bolted or Welded
- AISC: Clip Angle (DA)
- AS: Angle Cleat (AC)
- BS: Double Angle Web Cleat (DAWC)
- CSA: Double Angle (DA)
- EN: Double Angle Web Cleat (DAWC)
- GB: Double Angle (CA)
- IS: Double Angle Web Cleat (DAWC)
- NZS: Angle Cleat (AC)
- Angle Type: Single or Double Angle
- AS: Bearing Pad (Bpad)
- CSA: Bearing Pad (Bpad)
- NZS: Bearing Pad (Bpad)
- Beam Skew Angle: 5º < θ < 70º
- Plate Type: Single or Double Plate
- AISC: Stiffened Seated (SS), Unstiffened Seated (US)
- AS: Seating Connector (SC)
- CSA: Seating Connector (SC)
- IS: Seating Angle (SA)
- NZS: Seating Connection (SC)
- Top Angle Location: Top or Side
- Stiffener Element: Angle, Tee, Plate
- AISC: Double Shear Plate (DSP)
- AISC: Unstiffened Seated HSS (USHSS)
