| Version: | CONNECT | ||
| Area: | Reference | ||
| Subarea: | N\A |
When you need to generate a report to show which reference files are turned on, perform as described below:
Go to Analyze Tab > Reports > New Category > Enter the name (in my file “Reference”)
New report definition > (in my file “Reference on”)
Set the values in Properties on the right side as shown below
> add File Name and Display Columns > Preview results > Export results if you are satisfied
| Original Author: | Klaudia Piekielniak |
