RAM Connection 2024 (v24.00.00.140) Release Notes – Updated February 2024
Features:
1. Update AISC steel connection design to AISC 360-22: The AISC steel connections design has been updated to the latest AISC 360-22 for all available connections under AISC design code.
Figure 1. Steel connection design update to AISC 360-22
Some of the relevant changes of the update are:
CHAPTER J
CHAPTER K
MANUAL
2. New HSS beam to HSS support shear connections: Hollow Structural Section (HSS) beams are increasingly favored as beam members in contemporary construction, necessitating reliable connections to link these beams with supports. In that sense, two new connections were included for HSS beams to HSS support connections. The double shear plate and the unstiffened seated connection.
For the double shear plate connection, two plates are located on either side of the beam, sandwiching the HSS member. The plates have holes aligned with each other and the HSS members, allowing bolts to pass through, thereby creating a secure and robust connection.
Figure 2. HSS Double shear plate connection
For the HSS unstiffened seated connection, one HSS member is seated onto another, and welds secure the connection, providing resistance against forces. This connection is particularly effective for applications where ease of assembly is important, and additional bracing elements are not needed.
Figure 3. HSS Unstiffened plate connection
3. New joint data display panel: A new joint data display panel has been included in RAM Connection to show the joint data. This new panel allows to show in a more comprehensive manner all joint information and provides the option to edit member details like section, material and some others without the need to go to the Edit joint dialog.
Figure 4. New joint data display panel
4. AISC Base plate new anchor bearing plates: Now it is possible to define bearing plates for anchors in order to improve the pull-out in tension capacity modifying the bolt bearing area. In that sense, it is possible to define the bearing plate length in which case the bearing plates are displayed in the 3D and DXF drawings or define the bearing plate area directly.
Figure 4. New anchor bearing plates
6. AISC tubular truss connection design for large, gapped joint: This new feature allows appropriately design tubular truss joints with significant gaps. Now when a large gap is defined, joints are designed as individual connections avoiding the need to model two separated joints.
Figure 5. Tubular truss connection with a large gap
Resolved Issues:
