| | Product: | MicroStation, PowerDraft | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Driver/PDF | |
Description
I have a DGN file with a number of raster images attached. When I sent it to print in PDF, I would expect the rasters to be on separate levels but this does not seem to occur within the PDF that is output.
Steps to Resolve
The steps are:
1. Choose the pdf.pltcfg (or your own PDF-printer driver configuration file),
2. Edit the printer driver configuration file
3. In the Base Properties > Driver Properties> Enable Optional Content > On
4. In the Advanced section > Enable Merging of Background Rasters > False
5. Save the changes to the .pltcfg file, and
6. "Reload Printer Driver Configuration" for effect to take place.
See also
Other language sources
| | Original Author: | Judy Wong | |
