| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | General | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How to activate water tank structure option in RCDC?
RCDC has a module dedicated for designing water tank structure. As of now it supports only Euro code. So, in the design code section if any other code is selected apart from Euro code (EN) the module remains inactive. Once user changes the code to Euro the option gets activated automatically.
Even after that if it does not get active please check if the file is selected under analysis data.
