iTwin Analytical Synchronizer is the Engineers gateway into the world of digital twin, interoperability and collaboration. Don't waste time re-modelling the same thing in multiple applications only to repeat that as the designs change. iTwin Analytical Synchronizer helps you break out of your applications data silo, provide clarity to your workflows and helps your team collaborate more effectively.
Break out of data silos
Sync your models from your apps
| or |
OpenBuildings |
ProStructures |
REVIT |
STAAD |
RAM |
RAM Concept |
IFC |
TEKLA* |
SACS |
AutoPIPE |
RCDC |
RAM Elements |
Do more with Cloud Sync
Team player?
| Features | ||||||||
| Interoperability | ||||||||
| Collaboration | ||||||||
| Cloud Services | ||||||||
Cloud Sync provides interoperability and collaboration solution for dispersed teams
Your dispersed team can Push & Pull model changes round the clock.
Leverage Analytical Design Review to check design status and other modelling assumptions.
Discuss and comment on Issues anchored to your cloud model.
