Applies To | |||
Product(s): | MicroStation | ||
Version(s): | V8i | ||
Environment: | N\A | ||
Area: | Cells | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
When trying to replace cells with cells from a converted V7 cell library, they appear with a scale of one, but required scale is 50.
Scalefile.mvba will rescale the cells in the file to the correct scale.
This mvba can be found here:
http://communities.bentley.com/communities/other_communities/bentley_library/m/bentley_library_utilities/138914
