Product: | MicroStation | ||
Version: | V8i, CONNECT | ||
Environment: | N\A | ||
Area: | Interchange | ||
Subarea: | General |
How do I display more than BIM Data in Primary Tools\Items?
In the Items tool dialog click the top left icon 'Open Tree Manager'.
Select 'Change', then 'Show Advanced'.
Toggle 'Property Enable Searching' from none to All or Engineering Content.
Then select Open, and Close the dialog.
When exiting and reopening, the Items dialog will again set to the BIM default, requiring this process again to show more data.
To display Items in MicroStation you must have a published i-Model. For Bentley Building applications DGN or i-Model will Suffice.
Original Author: | Bentley Technical Support Group |
