iTwin Analytical Synchronizer 2023 Update 1
Release Date:  15th June 2023
Release Name: iTwin Analytical Synchronizer 2023 Update 1
Release Version: 23.01.00.119
REVIT
This update of iTwin Analytical Synchronizer resolves a clash in assemblies between external add-ins (such as REVIT Dynamo) and the iTwin Services experience within REVIT. The resolution for the aforementioned involves the iTwin Services Sidebar to be "undocked" in REVIT.
The iTwin Services sidebar is present in all iTwin Analytical applications. This update improves the about screen with more useful information including ability to quickly ascertain the relevant API versions and access to Logs. This feature helps our support staff to diagnose faults and crashes.
Analytical Design Review
Within Tendon Visualization in Analytical Design Review, the selected tendon properties pane is now more intuitive to use.
  1. Select Tendon Visualization mode.
  2. Select Tendon On screen in the 3D viewer.
  3. [New] Tendon properties pane showing the properties of the tendon segments. Properties are grouped whenever possible.
Bug fixes
Security, Maintenance and Stability fixes
This update also includes many security and stability fixes. As with general practice, API releases are supported for at least 3 years. Currently ISM API 8, 8.1, and 9.1 are supported.
