Product: | MicroStation | ||
Version: | V8, XM, V8i, CONNECT | ||
Environment: | N\A | ||
Area: | Levels | ||
Subarea: | Level Manager |
How to specify a Child Filter Name through a key-in
parent filter name.child filter name
If the parent is called "base plan" and the child is called "existing work", the key-in to set the Active Filter to "existing work" would be the following:
active level filter base plan.existing work
Original Author: | Erik Lofgren |
