| Version: | 08.11.09.459 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
What is the difference between the various preprocessor directives?
| = | Assign new_value to VARIABLENAME |
| : | Assign new_value to VARIABLENAME only if that variable does not already exist. |
| + | Append new_value to current value of VARIABLENAME. Uses a space as a separator. |
| > | Append directory or file lists defined by new_value to a variable definition that defines a path. If no current value for VARIABLENAME exists, this is equivalent to the = operator. Otherwise, it appends a path separator character, a semicolon (;), and then new_value. |
| < | "Prepend" directory or file lists defined by new_value (to the beginning of) a variable definition that defines a path. If no current value for VARIABLENAME exists, this is equivalent to the = operator. Otherwise, it prepends new_value followed by a path separator character, a semicolon (;). |
