| Version(s): | v8i, CONNECT | ||
| Area: | CONNECT Advisor | ||
| Subarea: | N\A |
When the CONNECT Advisor starts in conjunction with MicroStation, a script error appears.
The CONNECT Advisor is unusable after exiting out of the script error window.
When selecting any of the tabs or links within the CONNECT Advisor, multiple script errors are generated.
The issue is consistent and is also reproducible when launching the CONNECT Advisor from the Help tab within MicroStation CONNECT Edition.
This is a known issue with the CONNECT Advisor version 10.1.0.284.
Uninstalling the CONNECT Advisor via Windows Control Panel and then reinstalling a previous version of the CONNECT Advisor from the portal at https://softwaredownloads.bentley.com is a known solution.
Specifically, some users have confirmed that reverting back to version 10.1.0.245 of the CONNECT Advisor has served as an applicable workaround.
| Original Author: | Jayson Perry |
