| Version: | CONNECT | ||
| Area: | Coordinate Systems | ||
| Subarea: | General |
Did you know that in the CONNECT Edition, the shortcut key to toggle between Rectangular and Polar coordinates, is now activated by <M> ?
Press <F7> to display a popup list of AccuDraw shortcuts (this function key is assigned to the 'keyboardshortcuts displaymenu' key-in). Using the <?> key will also list these in a dialog.
The Change Mode between Rectangular and Polar coordinates was previously activated using the <SpaceBar> in V8i versions.
The significant change to adapt to is that the Space bar is now used to open the Ribbon Group Pop-up.
Check this section Complete List of AccuDraw Shortcut Key-Ins in our online documentation.
| Original Author: | Judy Wong |
