| Product: | MicroStation | |
| Version: | V8i, CONNECT | |
| Environment: | N\A | |
| Area: | Animation | |
| Subarea: | General | |
Using smart lines and Accudraw, we create camera paths and focus points that dictate the camera movements as we fly through our model.
- Open your 3D model
- Select Place Smart line
- Press F11 to activate Accudraw
- Snap in a point and press key O to indicate that this is the origin in the Accudraw compass
- Press E to change Accudraw direction
- Draw the line or patch to follow
- Using element information change from general tab the line class from primary to construction so the line is hidden during animation
- Use Utilities menu\Render\Fly though camera settings
- Set the number of frame (frame=Number of cameras placed in different points)
- Fly though producer\Tool\define a patch-> Identify Element at path beginning and identify ending of the path
- Define a target point
- Tools\preliminary view \view
- Once everything seems to be ok you can create a video
- Utilities menu\Render\Fly though
- Tool\Record\select directory to save video-> Select type of sequence of recording ( example AVI) ->ok
http://www.youtube.com/watch?v=3yEusZy0Mkk
See also
Other language sources
| Original Author: | Maria Munoz | |
