| Application | PLAXIS 2D PLAXIS 3D  |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 2D 2012.00 PLAXIS 3D 2012.00  |
| Found in Version | PLAXIS 2D 2012.00 PLAXIS 3D 2012.00  |
| Fixed and Released in Version | PLAXIS 2D AE PLAXIS 3D 2013  |
| Issue # | 18449 |
| Date created | 18 January 2013 |
Although the PLAXIS post-processor is supposed to be a general tool, serving both PLAXIS 2D and PLAXIS 3D, it is strongly recommended to use the original Output program of the corresponding PLAXIS version. PLAXIS does not guarantee full compatibility when using the Output program supplied with the PLAXIS 3D package to visualise results from PLAXIS 2D models, or vice versa.
A known example where inconsistency occurs is when presenting ‘Active pore pressures’ for a 3D 2012 project in the recent PLAXIS 2D (2012) Output program. In fact, the presented pore pressures ALSO include Suction, whereas Suction is NOT included when presenting Active pore pressures for a 2D project. Furthermore, when presenting total stresses of a 3D 2012 model in the recent 2D (2012) Output program, the results will not be as expected for the same reason (total stress = effective stress + active pore pressure).
Using the incorrect Output program for e.g. PLAXIS 3D 2012 results in PLAXIS 2D 2012’s Output can occur:
The issue does NOT occur when using the Output program of the corresponding PLAXIS version. You can check which version you are using via the Help > About menu item in the Output program.
In order to prevent inconsistency in the shown results, use the original Output program of the corresponding PLAXIS version, i.e.
Please check this in the Help > About menu item in the Output program.
Since PLAXIS 3D 2013 and PLAXIS 2D AE, the PLAXIS Output program will not reuse incompatible Output programs from other PLAXIS versions to prevent showing results in an incorrect Output version.
