| Version: | CONNECT | ||
| Area: | Text | ||
| Subarea: | General |
I need to be able to display special formatting symbols such as the Carriage Return symbol (¶) and space symbol (⋅) when I am editing my text within the Text Editor while using MicroStation CONNECT.
While in the Text Editor:
1. Right click in the empty space
2. Navigate to Display Options
3. Select "White Space"
BEFORE:
AFTER:
These symbols can also be displayed with the keyboard shortcut CTRL+Shift+8 if the Text Editor is the active window.
Text Editor Window - Online Help Documentation
| Original Author: | Jayson Perry |
