| Version(s): | 10.16.00.80 | ||
| Area: | Raster | ||
| Subarea: | Bing Maps |
MicroStation exits when attaching Bing Map.
User is connecting to internet via a Proxy environment
Proxy was set to "Use System Proxy Settings" in Bentley Licensing Tool
Changed to "Use Custom Proxy Settings" and Bing Map attach works.
• Open Bentley Licensing Tool
• Go to Tools > Options
• Set Use Custom Proxy Settings
• Enter Proxy Server/Port details ProxyIP:PortNo
• Enter Proxy Server Authentication if applicable
• Test Proxy Configuration
• Click Apply, OK button to save the settings
| Original Author: | Leonard Jones |
