| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 2D AE.00 PLAXIS 3D 2013.00 |
| Found in Version | PLAXIS 2D AE.00 PLAXIS 3D 2013.00 |
| Fixed and Released in Version | PLAXIS 3D 2017.00 |
| Issue # | SW-14750 |
| Date created | 23 July 2014 |
| Date modified | 13 September 2017 |
For the calculation of active pore pressures in Plaxis we distinguish between two types of analyses, a semi-coupled analysis and a fully coupled analysis:
A Safety analysis is a semi-coupled analysis based on steady-state and excess pore pressure. At the start of the Safety analysis these steady-state and excess pore pressures are the results of the phase for which a factor of safety is to be calculated. However, if the factor of safety must be determined from a fully coupled flow-deformation analysis, the steady-state pore pressures of this fully coupled phase are in fact the pore pressures from the independent steady-state groundwater flow analysis and the excess pore pressures are zero. The real pore pressures that result from the fully coupled analysis are the active pore pressures. This means that a Safety analysis following on a fully coupled analysis will by default use the results of the steady-state groundwater flow instead of the real active pore pressures which leads to an incorrect factor of safety. Additionally, the steady-state pore pressures always includes suction even when the fully coupled analysis used the “Ignore suction” option, which is likely to cause an overestimation of the factor of safety.
This issue is solved in PLAXIS 2D AE.02: This problem is overcome by making the Safety analysis read resulting active pore pressures from the previous phase and consider them as steady-state pore pressures in case the previous phase is a fully-coupled analysis. This will ensure that the Safety analysis will calculate the factor of safety based on the correct pore pressures.
For PLAXIS 3D, the issue is solved in PLAXIS 3D 2017.00
