| Application | PLAXIS 3D |
| Issue status | ✔ Solved |
| First Affected Version | PLAXIS 3D AE.00 |
| Found in Version | PLAXIS 3D AE.00 |
| Fixed and Released in Version | PLAXIS 3D AE.01 |
| Issue # | 23611 |
| Date created | 15 May 2015 |
When loading a project in PLAXIS 3D AE.00 that was created in the PLAXIS 3D 2013.01 version you may encounter one of the following issues:
The problem is caused by a conflict in the visualisation settings only, without affecting any other data of the project.
This issue is now solved in PLAXIS 3D AE.01
For PLAXIS 3D AE.00: To fix the problem, the file containing the visualisation settings for the specific project should be removed, by following these steps:
Note that the deleted file only contains visibility settings for all items in the program (status of the eye in the Model explorer) and nothing else. This means that when removing this file, it will only have an effect on these visualization settings and it will not change anything else in your model.
